Got headers installed, terrible idle now.
Old Feb 13, 2004 | 07:44 AM
2000WS6Vert's Avatar
Default Got headers installed, terrible idle now.
I just had a shop install my headers and now the car feels like it wants to stall. The idle sounds like it has a misfire in it...then proceeds to dip below 500 rpms. It also sounds like there could be a leak, it's a slight hissing noise coming from somewhere. Could a leak cause what sounds like a misfire from the exhaust? What could the installer could have done inside the engine bay to cause this if a leak isn't the problem?
Oh...these are Hooker LTs and custom ORY and stock exhaust....it sounds great!!!
Old Feb 13, 2004 | 08:02 AM
Slowhawk's Avatar
LS1Tech Sponsor
First I would check the EGR tube going into the intake for leaks.
Old Feb 13, 2004 | 08:05 AM
1STGEN68-2000SS's Avatar
Check your plug wires.
If the system was set up for egr check for air leaks at the intake manifold were the upper tube goes in. If the light is flashing that is a miss fire code.
Alan
Old Feb 13, 2004 | 08:06 AM
Slowhawk
You type faster than I do.
Old Feb 13, 2004 | 09:11 AM
smokin' joe 00 ss's Avatar
Yea it's most likely the o-ring on the egr at the intake is not seated right.
