FIX ls1 or 6.0 swap?
Im the kind of person that doesnt like to fix things back to stock.. If I have to make a repair its gonna be worth it .. So low on cash at the time from buying a new truck I dont exactly have the coin to drop on a bad *** head cam combo . Im thinking over the summer Ill gather parts and go for it by fall.. What would be cheaper? swap or head and cam..
1)I was thinking buying a used 6.0 truck motor and buying a turbo cam oil pump and so on and swapping it in then later on putting a turbo kit on it.
2)Ive not done a headjob on a fbody but it looks like a pain in the *** and I dont see arp studs being used unless I drop the motor out so on that note mite as well had some cubes.. Then later on going through the ls1 and swapping into my 86 monte ..
ls1 has 170k
Opinions and info o the swap greatly appreciated..
You can always freshen up your engine and then sale it to recoup money for your 6.0 build. Or, drop the money directly into the LS1 and save a couple hundred from not needing to buy a block.
