Random Misfire. Please Help.
Old Feb 24, 2011 | 10:18 PM
6LiterHawk's Avatar
Default Random Misfire. Please Help.
When I start my car it runs fine, then once it gets to running temp it starts misfiring very badly, almost to where the car is undrivable. Then after about 5 minutes of misfiring it smooths out and there is almost no misfire at all. Then after a bit it will start again. I'm kinda leaning towards a bad coil pack but have no idea. Thanks for any help.
Old Feb 24, 2011 | 11:19 PM
strokerrace's Avatar
Checked the O2 sensors?
Old Feb 24, 2011 | 11:30 PM
6LiterHawk's Avatar
im throwing a code about the passenger o2 sensor not heating up fast enough but that code has been there since last october, the car sat for a bit because i blew the tranny, then i put the tranny, and tranny cooler in and it started doing it.
Old Feb 26, 2011 | 07:11 PM
Behemoth's Avatar
any other codes? Could be the crack position sensor.
Old Feb 26, 2011 | 09:20 PM
bayer-z28's Avatar
Check around your coils to see if anything is cracked or arching to the valve covers. What wires are you running?
Old Feb 27, 2011 | 12:18 AM
juniorsws6's Avatar
Man bro I'm have the same problem I've already replaced my coils,wire,plugs this issue
Is driving me nuts and I just can figure it out please let me know what you come up with
Old Feb 27, 2011 | 03:22 AM
Mumbles's Avatar
Originally Posted by Behemoth
Any other codes? Could be the Crank Position Sensor.
I'd also like to know if you're getting any other Codes.
The Crank Postion Sensor would be a great candidate for the cause of your misfire. If you decide to pursue this direction, I would recommend spending the extra cash to get a GM CKPS from the dealership or from an Online source.
I replaced mine in my 99 Sonoma, fighting a misfire, with an Autozone Sensor (twice!) and it gave me a Crank Position Sensor Intermittent Signal Code. Installed a GM Sensor and it cleared up this code and most importantly the misfire.
