FAST 102mm LSXrt Question
And IIRC, the RT intake has longer runners for low end tq that the trucks need.
Check here for more 102 info.
https://ls1tech.com/forums/generatio...02-thread.html
NW 102mm tb
102mm opening. You can see some of the porting in the tb opening
Crappy cell phone pic but you can see some of the porting work.
Pulled cover off to clean inside and drill hole for MAP sensor.
Reg grey color gets dirty easy. Decided to paint it black. Red primer enamel here.
Industrial semi gloss black. Retained that textured look. Looks like it came black from FAST.
Bolted down. Waiting on fuel rails and ready to go.
