Ported Fast 92 with pics
Old Mar 16, 2011 | 08:38 PM
bayer-z28's Avatar
Originally Posted by silverz28camaro
How do you like your 102? is the port match to cylinder head better then the 92?, o is there stil alot to open up there?
The 102 is a bit of a pain to install on an F-Body though. it's so frickin massive it takes up a LOT of room. Needs an LS2 waterpump also. Or else you'll just end up installing and removing the intake and TB about a half a dozen times until you get the clearance right. (grind the **** outta the stock LS1 WP. dremel, 4.5" angle grinder, sandpaper, swearing and broken tools thrown against the wall.)
But there's a TON of room for expansion. They lower matches almost perfectly to my ported 243 heads. (Rather small port) but like most of these FAST intakes, there's a lot of smoothing to be done. I'd highly recommend having Tony Mamo work his magic on them.
Old Mar 16, 2011 | 08:48 PM
silverz28camaro's Avatar
Yeah Tony is the man, but I'm putting my $500 towards other things..
I still need a new fuel pump, tires, and money for changinf my exhaust over..
Old Mar 16, 2011 | 10:13 PM
WSsick's Avatar
Good **** Brad!
Old Mar 17, 2011 | 09:41 PM
WS6 SRT-8's Avatar
Nice job, Brad!
Old Mar 18, 2011 | 05:26 PM
LilJayV10's Avatar
Does anyone have any instructions on how to put this thing back together. I took mine apart today and cleaned it, good thing I did, it was full of metal shavings and the gasket was out of one of its tracks.
Is there no gasket between the lower and mid part? I know there is RTV used throughout the intake and I was wanting to know where.
Thanks.
