FlowTech long tube headers
Old Feb 17, 2004 | 09:21 AM
tbyrne's Avatar
Default FlowTech long tube headers
These headers have just been released for the LS1 -
FlowTech headers are precision engineered and leak tested to get maximum performance and fuel economy from your engine. Each header is formed from specially selected .049 cold roll flash controlled tubing, and features FlowTech's exclusive, thick, mandrel-formed Power PlenumTM collector. All ports are precisely fitted and finished with sturdy, leak-proof O-ringed port seals, and all FlowTech headers include all mounting hardware including bolts, nuts and premium gaskets.
FlowTech headers are available with either a high-quality, electrostatically-applied PPGTM satin black paint finish or with a specially formulated, NASA-developed silver luster ceramic coating for rust and corrosion resistance.
Mandrel-formed Power Plenum collectors for low backpressure
Constructed of .049 cold roll flash tubing
Precision engineered for fit, performance and economy
Includes all mounting hardware and premium gaskets
The headers range between $270.-$370. and $130. - $230. for the offroad Y-pipe.
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
SUPERCHARGER DISCOUNTS AVAILABLE!
Old Feb 17, 2004 | 09:27 AM
CHRISPY's Avatar
Tom,
Do you have these in stock?
PM me moderator price for a coated set of flowtechs and a noncoated Ypipe.
Thanks,
Chris
Old Feb 17, 2004 | 09:43 AM
CamaroCain's Avatar
moderator price, blah, what you talkin bout
Old Feb 17, 2004 | 02:52 PM
Fred99LS1's Avatar
For $500 I'm going to buy a set of coated Flow Tech headers & uncoated Y-Pipe. Do they sell them without the o2 fittings? I think I'm going to get rid of my cat's. I'll just buy some o2 simulators. Thanks, Fred
Old Feb 17, 2004 | 04:12 PM
demonspeed's Avatar
It's not mine! woo hoo!
How does the quality and fit of these compare to the Pace Setters and Hookers? How does the y-pipe look? I might consider these...
Old Feb 17, 2004 | 04:24 PM
2xLS1's Avatar
You still have to have O2 bungs for the front O2s.
I saw this on another board. I am not the one who emailed them I just copied and pasted this from the other board.
Many of us have questioned why flowtech lts look the same as Hooker LTs in pictures, and wonder if they are the same header..
this is an email response that I received from one of Hookers tech support and the questions that I asked..
Questions::
What is the difference between hooker headers and flowtech headers besides
flowtech being $250.00 cheaper?
Which brand of highflow cats do you recommend for your header/y-pipe
setup?
Once installed how much ground clearance does your headers leave?
ANSWERS FROM HOOKER TECH:
The Flowtech headers will not have as good of weld quality or bend quality and will also have a three bolt ring instead of the slip fit connection for the y-pipe. We do not reccomend one brand of cat over the other, you will just need to do your homework there. These headers hang down about
3/4" past the rocker pinch weld.
Thanks
Old Feb 17, 2004 | 04:51 PM
demonspeed's Avatar
Then why does it look like a slip fit in the pic?
Old Feb 17, 2004 | 05:14 PM
67SS&99SS's Avatar
I work at Advance auto parts and I called Hooker about these and they said that they wouldn't be available til the first of March. They also told me that the the flowtechs didn't have provisions for A.I.R. They never mentioned the collectors though. I want to see some pics when they come in because these are the headers that I'll most likely run on my Z.
 Michael S. Palmer
Old Feb 17, 2004 | 05:17 PM
foff667's Avatar
LS1TECH Sponsor
Originally Posted by Chris ARE 360
Tom,
Thanks,
Chris
Geez how do I become a mod around here
Old Feb 18, 2004 | 10:45 AM
NBM2001z28's Avatar
Restricted User
I hope they are released before that. Speed inc is suposed to have them this week. I'm waiting for my part.
Old Feb 18, 2004 | 12:19 PM
Inspector12's Avatar
TT-TECH Veteran
Let me know what you think when you get them Fred.
Jeff
P.S. Did you get my Email?
Old Feb 18, 2004 | 01:44 PM
LS1LT1's Avatar
I don't think that's a pic of the actual Flowtechs, I believe that's a pic of the 'similarly designed' (same parent company?) Hookers.
Old Feb 18, 2004 | 10:30 PM
demonspeed's Avatar
It's the same pic that Holley sent in our dealer cataloge updates... I'll just have to wait until I can get a set in my store to check them out
Old Feb 18, 2004 | 10:37 PM
Country Boy's Avatar
Senior Member
Speed Inc has a true pic of them in the sponser section It looks like they have the 3 bolt flanges.
