What else will i need???
Old Mar 20, 2011 | 12:44 AM
JeaneGrae's Avatar
Default What else will i need???
I bought a used ls6 intake, other than gaskets what else will i need to make it work on my 1999 TA? Any part numbers would be greatly appreciated. Thx in advance!
Old Mar 20, 2011 | 08:08 AM
bayer-z28's Avatar
You COULD do the LS6 steam vents, but it's not 100% needed. Should just be a bolt-in swap.
Old Mar 20, 2011 | 09:10 AM
RARON455's Avatar
You will need the LS6 steam tubes unless you grind the ribs on the intake, there are a ton of threads about that,,took me like 5 minutes and saves about 50 bucks. ALSO be careful or you will break your oil pressure sending unit and thatll be another 40 bucks. When removing LIFT UP the manifold and pull it out.
