IAC,maf, crappy tps
Thanks guys!
have you added anythign else here of late or any other mods htat might act up ?
did you get any gas while in ol mexico ?
the tps a trick with it is to tap on it lightly also make sure the gasket is still there .
have you took apart any of the componets ?
sorry for all the questions just trying to contemplate the ifs . try to give some more info on another ride . check your plugs , wires, conections , anything easy to get to before openeing it up .
could have a 02 that is not right .
The detonation, if it happened while at WOT, can be the MAF.
Go buy a new IAC valve, put it in, if thats it you're good. If its not it, return it for a refund. Just tell them its the wrong one and it doesn't fit. I've done this a million times with all kinds fo parts.
Just the exhaust that it's not fully tuned for. The gas was bought at a sunoco.
The problem is always when I put it in nuetral and let it go to idle. Then it either sticks up or surges down.
Yes the gasket is still there. I have taken the throttle body apart recently but the surging down to 500rpm has happened before.
How come some scanners Dont measure tps voltage?
And a iac is 100$ from the local auto parts store. I'll have to wait a little while before I can get it.
I also tuned the timing down a notch and checked it and there was no detonation.
