best plug wire combo?
Stock GM wires are fine, usually NGK plugs work well. Depending on what you have done determines your spark plug model choice and gap.
Spark plugs are like condoms, they all aren't universal.
The IX plugs are iridium and may last for 100,000 miles.
Most wires are pretty good except for the Taylors. Many here have had issues including myself. Avoid them.
GM wires tend to have high resistance. As I recall, the Acell wires are also pretty high.
I'm running the Granatelli wires. As stated above, they're zero Ohms. They MAY add some power but have a lifetime warranty. $105.00 direct from GMS, call in orders only for LS engines. Far away the most "worth it" plug wire set of the group.
I'm gonna try a set of the WeaponX spark plugs, they have no resistor in them.
