Just Got my CAT replacments.. Qs????
Old Feb 19, 2004 | 08:05 PM
greekss's Avatar
Default Just Got my CAT replacments.. Qs????
I just recieved my set of pipes to replace my cats... my question is on the longer one y is there an opening... is it for the 02 sensor? isnt that y i bought 02 simms? should i fill it or re-install the 02 sensor and the 02 sims? im confused. Another prob is can i just unbolt the cats and theyll drop, or will i have to unbolt the entire exhaust?
Old Feb 19, 2004 | 10:40 PM
greekss's Avatar
anyone have these ?
Old Feb 20, 2004 | 12:37 AM
greekss's Avatar
well then lol.........
Old Feb 20, 2004 | 01:53 PM
greekss's Avatar
Help Me Help You
Old Feb 20, 2004 | 02:03 PM
Gary Z's Avatar
Normally our cars have four oxygen sensors, one upstream of the cat and one downstream on each side. The two upstream sensors are essential. With cats removed, simulators replace the downstream sensors.
Old Feb 20, 2004 | 02:58 PM
LightweightZ28's Avatar
If you got the Mufflex by-pass pipes, the driver side pipe will have a hole for the front 02 sensor. On the stock catted pipe, the 02 sensor is on the pipe with the cat. So when you take the stock cat off, the sensor comes with it. You will need to transfer the sensor over. On the passenger side, the sensor is on the manifold just above the 3-bolt flange. So when you take that cat off, the sensor doesn't come off with it....which is the reason why only one of the pipes has the hole in it.
