Update on LS6 PCV....Still using oil!
I bought one called an Accurate Machine works Catch can.
It looks and should take care of all the issues.
I have an exhaust evac from Morosso also that goes to the breathers and might be good for a couple of HP.
I will use the catch can and if it doesn't go away I will be installing the exhaust evac to the valve covers.
Todd assures me that with the pcv mod and his catch can from accurate Machine works I should be good and clean on the tops of the pistons.
Maybe we won't have detonation on the # 7 piston and save a few engines.
We can put all this oil in the intake to rest and move on to making more power .
I believe the catch can I bought will fix it for good, but if it doesn't I know # 2 alternative will (exhaust evac)
John
I am headed to P'cola tonight to take my truck to Tim, I might swing by your place and check out the bike.....and a beer.
Jake
Jake,
I noticed it after some pretty good high rpm runs. (Quintette!!!) Checking my tuning. Not near as bad as before, but still some. Give me a call. I'm heading to Ft Walton to have my y pipe done tonight. The guy works at night so I might not be home until 10 or so, but I have a fridge full of budlight if I get back earlier or you stay later!
I'll look into the breather. Just gotta see if it will clear my STB.
