headers
Old Feb 19, 2004 | 11:48 PM
can't drive 55's Avatar
Default headers
Is a light ticking noise common when a car has headers. thanks for any feedback.
Old Feb 20, 2004 | 12:23 AM
FatZ28's Avatar
Sounds like you might have a small exhaust leak. If you just put them on you might want to go back and retighten the header bolts.
Old Feb 20, 2004 | 04:38 AM
jrp's Avatar
jrp
SN95 Director
exhaust leak or check valves if you still have your AIR system.
Old Feb 20, 2004 | 07:12 AM
cheez22's Avatar
Also, check spark plug wires. A loose wire will create a "ticking" noise too.
Old Feb 20, 2004 | 08:02 AM
00Streak's Avatar
light enough to hear with the hood open, yea, there will be a little. hood closed, not unless you have a leak somewhere.
S
Old Feb 20, 2004 | 12:51 PM
dheck's Avatar
Does the ticking increase as you accelerate? If so then it is probably an exhaust leak. What gaskets did you use?
Old Feb 21, 2004 | 07:43 AM
4mula's Avatar
im gonna guess its a leak.
Old Feb 25, 2004 | 10:55 PM
Default thanks for feedback
thanks for all the feedback, i'm gonna check all the header bolts, see if it improves and then i'll go from there. thanks
 Michael S. Palmer
