X-Pipe? H-Pipe?
Old Feb 20, 2004 | 07:40 PM
BlackCamaroSS02's Avatar
Question X-Pipe? H-Pipe?
Whats the difference (other then the obvious H pattern and X pattern) is there a benifit to having one over the other and what if you dont want an X or a H pipe what if you use straight pipes...is that better or worse. Need some info please
Thanks
~Tom
Old Feb 20, 2004 | 10:19 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
X-pipe will scavenge better than an H-pipe for obvious design/flow reasons.
An H-pipe will sound better usually though, but X- is the way to go.
Straight pipes won't benefit from the scavenging qualities of an X-junction.
Old Feb 21, 2004 | 12:45 AM
BLASTER's Avatar
Exactly what South said....
Here is a good acticle.....
http://www.carcraft.com/techarticles/69238/
There was another one around here but I can't remember what it was......
It illustrated that the X benefited down low and up top substantially and the H pipe beat the X only by a little in the mid range.
Old Feb 21, 2004 | 07:36 AM
4mula's Avatar
im a fan of straight pipes. simple and cheaper
Old Feb 21, 2004 | 12:15 PM
black_z's Avatar
Theres a reason NASCAR uses an X-pipe setup.
Old Feb 21, 2004 | 12:58 PM
Mike's02Z28M6's Avatar
That link rocks
Now, take their findings a bit further (and mabye a little wackier) but couldn't you get the best of both worlds by running a connecting pipe (H-pipe) a foot down further past the X-pipe towards the mufflers?? Now you get scavenging of the X and the H sound? Or am I a tard
Old Feb 21, 2004 | 01:45 PM
2001CamaroGuy's Avatar
Originally Posted by Mike's02Z28M6
That link rocks
if it has an x then it should sound like and x.....the x cancles out some sounds and therefore it will never get the "H-pipe" sound.
"H-pipes" do sound "slightly better" (more muscle) but to me its not worth the loss in HP.
