Stainless header temperatures????
Old Feb 21, 2004 | 01:42 AM
vader99's Avatar
Default Stainless header temperatures????
Will the stainless steel type headers retain the heat and keep the engine bay as cool as jethot coated headers?
Can you touch the stainless headers a few minutes after turning the car off and not burn yourself just like with coated headers or does the jethot coating actually keep the headers a lot cooler than the plain stainless steel ones?
Old Feb 21, 2004 | 08:59 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Stainless is just used to reduce corrosion, it is not any better at holding heat. Jet-Hot coated headers, being a ceramic coating, improve the coefficient of heat transfer, making them transfer less heat than bare metal.
You can't touch either of them after a few minutes, they will all burn you.
