head gaskets
Old May 5, 2011 | 12:45 PM
Thetal1's Avatar
Default head gaskets
im building a 383 ls and need head gaskets that will fit seeing how its bored 5 over and they need to be the same thickness as stock so my compression wont be affected. i dont know where to look so any help is welcome
it came out of a 00 ws6 and has ported milled 5.3 heads.
Thank-you
Old May 5, 2011 | 12:57 PM
BIG_MIKE2005's Avatar
Go grab a set of stock MLS gaskets & you should be fine. I know the MLS gaskets have alot better track record than most other options. Try a search in the internal section as well, you'll find more there.
