fast fuel rails
Old May 5, 2011 | 04:50 PM
blkgagt94's Avatar
Default fast fuel rails
i got a set of fast fuel rails an i was wording where i can buy the rest of the fuel line to connect to the other side
Old May 5, 2011 | 06:36 PM
jpoole's Avatar
Well on my CTS-V, I went to Summit Racing and got some Russel products, there are other brands out there.
I used:
2 - 8an 90 degree full swivel elbows to connect the 2 fuel rails at the front
O-ringed Pipe plug (passenger side rear)
6an 90 degree elbow and male GM fuel system connector on the drivers rear
I used about 8" of 8an hose to connect the rails in front & 6" of 6an hose to connect to the fuel system from the rear of the drivers side
The kit should come with the 8an & 6an Pipe O-ringed connectors.
Look at your fuel system and kinda draw it out.
I used the nylon hose and the easy connectors. Also recommend getting a hose cutter, does a good job.
Also, Mast Motorsports sells pre-made kits. I bought one, but it was 2 long and I had to take it apart, cut it off, and re-install the elbow. I would measure and tell them how long to make it. They are good guys and easy to work with.
Another question on their rails. I have a Fast fuel rail 146032-KIT, does anyone know if that will bolt to a factory LS6 intake or just a Fast intake?
