weiand air ram intake
Old May 5, 2011 | 05:07 PM
rio95cobra's Avatar
Default weiand air ram intake
I've never seen this intake before, but a guy on craigslist is selling one for 375 bucks, and I'm just wondering if I should buy it instead of an oem ls6 intake.. what do you guys think? And how does this stack up in terms of making power against an ls6? I'm also assuming this intake isn't the same as the weiand lingenfelter, because it looks slightly different.
Old May 6, 2011 | 01:14 AM
99Bluz28's Avatar
IMO, the BBK SSI aluminum intake is a better option, you can use up to a 85mm tb and it uses stock gm gaskets to seal it to the heads. If you don't want to go with the BBK then go with the GM LS6 intake.
FYI the Weiand air ram, is the same as the Weiand Lingenfelter, except for some cosmetic differences.
