True duel exhaust guys, input needed!!!
Old May 18, 2011 | 02:09 PM
Marc 85Z28's Avatar
Boomtubes are meant to be functional. Unless that extends all the way to the balance tube (H or X pipe) on the exhaust, it's merely a fancy exhaust tip. There are lots of companies selling "boomtube" exhaust tips.
Old May 18, 2011 | 02:48 PM
firemech21's Avatar
I was able to locate a set of boomtube plans, that i scaled down to fit the dimensions I wanted. That how I made them, now mine will have a spiral flow muffler in between the "tip" and x pipe. To help quite the car down a bit. As for tips I couldnt find any.
Old May 18, 2011 | 02:56 PM
1990LSx's Avatar
too each his own. I do not like the way it looks but it is your car. Post up sound clips when you are done. It does look a little low to me though.
Old May 18, 2011 | 08:35 PM
babbage1109's Avatar
that looks badass i really want to do that with my setup. get pictures of the underside and everything too please!
subscribed
Old May 19, 2011 | 09:25 AM
firemech21's Avatar
Thanks babbage1109, i hope it turns out well. I will take a bunch of pics once im finished.
Old May 19, 2011 | 09:56 PM
what about just using these....http://www.stainlessworks.net/produc...-id-inlet.html
this got me thinking using the tsp dual system and putting pipe from the resonator to the tips on the side instead of turndowns....?
Old May 20, 2011 | 05:49 AM
firemech21's Avatar
The only problem going from the resonator out the side would be clearence between the LCA's. I have the TSP system. My thought are take the system off, remove the 2 pipes from the back of the X-pipe and weld the mufflers there. Then have a slip connections right into the pieces i am making. I had my car in the air the other day setting this up and getting measurements. Then the flow out of the x-pipe will be a straight line, the less twists and turns the better I think. As for using the oval piping, go for it. I used the round because with all the crap i have in my garage, I was able to adapt the 3" round into the boomtube with 2 pieces of sheet metal and looking inside the pipe it looks good.
Old May 20, 2011 | 06:18 AM
I guess I really don't know how far back the tsp actually goes. Idk if it could be shortened or reconfigured but im real interested in how you do yours haha it will look great no matter what
Old May 20, 2011 | 06:54 AM
firemech21's Avatar
LOL thanks again babbage1109. I guess i get to be the test subject. The TSP kit goes back just past where the unibody turns upwards to go over the rearend. I would say maybe 4-6" past that. If you have ever looked at the kit though it can by modified like i said in my last post and it will run straight off the x-pipe and out. I had to cut the exhaust at a different angle (12.5* I think) in order for it to be parallel with the side skirts. But when i had it mocked up from the lowest point i had just under 3" of ground clearence. But when i modify the x-pipe and put some rear suspension goodies on, I should have around 3.5" of clearence. I think that will be plenty for my purpose.
Old May 20, 2011 | 08:58 AM
1Psycho's Avatar
Looking good man! Does it hang any lower than the tsp system already does on our cars? Interested to see how it sounds. Think this just might be my next project too haha
Old May 20, 2011 | 11:25 AM
firemech21's Avatar
This setup doesnt hang as low as the TSP true duels does. From my measuring this is 5/8" higher than the lowest part of the TSP system.
Old May 23, 2011 | 07:54 AM
  #32
firemech21's Avatar
Well i finished welding the second piece together. Need to grind down the welds, then paint and bake. The wife says she is going to kill me if the house smells b/c I only have 1 oven. Has anyone baked paint in their oven?
Old May 23, 2011 | 08:48 AM
  #33
mike c.'s Avatar
O1REDSSA4-I read the link you put on true dules. The only think i've seen wrong is the guy satted he runs GUTTED cats. This is not good and has been proven by me and a few friends. When you have a cat that is gutted it causes an exspanshion chamber in the exhaust and loses power. Back in the day everyone used to gut the cats on the 5.0 mustangs. I did it too and noticed my stang slower. We did this on a 99 camaro as well,ran it for times then gutted the cats. He already had headers and off roads wating to be installed so this would not hurt. Once again,the camaro lost over 2 tenths in the 1/4mi. Even on my old 5.0 i felt a loss and a return when i got a proper h pipe. Just get an off road pipe and keep the cats in the garrage.
Old May 23, 2011 | 10:05 PM
  #34
firemech21's Avatar
Finally finishing the second side. Now on to getting the ready to go onto the car.
Old May 26, 2011 | 05:33 PM
  #35
firemech21's Avatar
I was able to try them out today and WOW. I think that they sound great. I slid them over my exhaust that currently on the car and fired it up to hear them, didnt get any vid. The exhaust mellowed out in tone and has lower rumble that sounds great.
Old May 29, 2011 | 11:54 PM
  #36
1Psycho's Avatar
Video! Video! Video! Wanna hear how it sounds man! I'm really thinking about doing this to give it more of an older "side pipe" mellow but rumbly sound. Let's hear it!
Old May 30, 2011 | 10:00 AM
  #37
firemech21's Avatar
I just finished the priming yesturday, hopefully i will get them painted today. Video is going to be a bit. I have almost an entirely new engine worth of parts that are going under the hood this weekend.
Old May 31, 2011 | 10:04 AM
  #38
5w20's Avatar
Medieval stuff going on in here!
Old Jun 4, 2011 | 11:44 AM
  #39
firemech21's Avatar
I pulled the engine from my car to start rebuilding it. So hopefully I will finally post a video of the exhaust system in a few weeks once the engine and those parts are installed.
Old Jun 4, 2011 | 09:17 PM
  #40
Mike 02T/A's Avatar
Originally Posted by firemech21
I've been looking at my system right after the x-pipe there is about 10" of pipe then the mufflers. What im planning is remove the pipe, and attach them right to the back of the muffler.
What mufflers did you have w/ The TD's? Was it DynoMax bullets by any chance? That last section should be in one piece.
