Battery Wiring! Need help!
Old May 23, 2011 | 02:40 PM
Bouvs's Avatar
Default Battery Wiring! Need help!
Hey guys, I have my new engine in the car and I've started putting it back together.
One snag I've run into is I removed the entire battery cable harness that runs from the battery, altenator, positive auxillary post and starter. I have it all put back in place since it was all obvious except for one thing. I can't remember where the hell I disconnected the negative ground wire by the starter? There is a pair of cables *pos. & neg.* that run down the chassis on the passenger side to the starter. The positive hooks onto the starter and the other I assume is a chassis ground. Could anyone please take a peak underneith their car and tell me where its attached. Is it hooked to the engine, the chassis and where exactly.
I really need your help guys, I only have certain days I can work on this thing and I need to get my car running for my wedding.
thanks.
Old May 23, 2011 | 02:51 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I can't find an exact photo but this is from the parts book. It's the cable that goes under the bolt narked 16. It's into the block. I hope this helps.
Old May 23, 2011 | 02:57 PM
Bouvs's Avatar
thanks alot man that REALLY helps I should be able to figure it out now!
thanks a million.
Old May 23, 2011 | 03:00 PM
Paul Bell's Avatar
Originally Posted by Bouvs
thanks a million.
GREAT. Paypal it on over!
Old May 23, 2011 | 06:22 PM
usafws6's Avatar
its right above the starter. anywhere on the block is fine though.
