Priming oil system
Old Jun 14, 2011 | 03:24 PM
QuadratSS's Avatar
Default Priming oil system
Does anyone know if you can prime the oil system on an ls1? My 02' camaro ss in coming out of storage this weekend. It has been sitting for two years and I don't want to cold start it if I don't have to. I would like to prime the oil system, but I don't know how. Wish it was as easy as pulling the distributor and spinning it with a drill.
Old Jun 14, 2011 | 05:52 PM
parks450's Avatar
Drain the oil the replace it. Unplug the coils and fuel pump turn it over a few times. Bout the only yhing I can think of
Old Jun 14, 2011 | 06:00 PM
gofastwclass's Avatar
That is the procedure listed in the GM Performance Parts manual.
All you need to do is remove the coil and fuel pump fuses for a simpler version of the same effect.
Old Jun 15, 2011 | 12:21 AM
94mustang's Avatar
unfortunatly this is the only way
Old Jun 15, 2011 | 06:55 AM
QuadratSS's Avatar
Thanks guys. That's about all I could think of myself. was going to pull fuel pump fuse, but now I will pull the one for coils as well. Fresh oil was put in the car prior to being stored, but still gonna replace it anyway before priming. Such a shame to see $60 worth of royal purple go down the drain. Thanks again for the advice guys a appreciate it.
Old Jun 15, 2011 | 08:11 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Agreed on the priming part and if you know it will be sitting, use cheap oil or at least prime with the synthetic and then swap it out with fresh.
Old Jun 15, 2011 | 07:57 PM
S10xGN's Avatar
How accessible are the plugs? If you pull them, there'll be a whole lot less stress on the bearings while cranking. Think of it as the difference between an engine "trying" to start (full compression) vs. turning it over with a breaker bar during assembly...
