Engine noise, Weird hum/whine!!
Old Feb 26, 2004 | 08:32 PM
Speedy0009's Avatar
Default Engine noise, Weird hum/whine!!
This annoying noise is coming from my engine bay. Its not the power steering pump nor the alternator. So I will soon be trying a new tensioner pulley. Any other suggestions?? With the serpentine belt off this noise does not exist.
Any help is appreciated, thanks.
Old Feb 26, 2004 | 09:59 PM
zombie1's Avatar
Try this while the motor is running with the belt on, carefully spray a little water on the belt if it shuts up, then it's the belt, inspect the belt for pieces missing or Large cracks when is is off, sometimes tensioner pully bearing can go bad and make the belt not run true,i.e. off center. recommend goodyear gatorback belt, expensive but lasted over 121,000 miles on my moms car.
