cutout for borla
Old Jun 23, 2011 | 09:30 PM
schuz_GXP's Avatar
Default cutout for borla
Can I use any 3" E cutout or does it have to be a special one?
Old Jun 23, 2011 | 10:43 PM
libertyforall1776's Avatar
DMH is reportedly the better choice, and what I went with.
Old Jun 23, 2011 | 10:57 PM
jrzdude's Avatar
Where are you mounting it? If it's going somewhere on the I-pipe (under rear passenger seat) than it'll be 3". I have a Borla cat-back and put a 3" QTP E-cut out on the I-pipe underneath RR seat.
Old Jun 24, 2011 | 04:37 AM
gocartone's Avatar
Guessing you mean where the adjuster plates go, right? As far as I know anything will work. I have the normal QTP on mine and it fit just fine. I love that I can have that straight piped sound out the back with the major drone inside.
Old Jun 24, 2011 | 05:30 AM
schuz_GXP's Avatar
Yes at the adjuster plate location.
Old Jun 24, 2011 | 08:17 AM
Quick Time's Avatar
Our part number for the Borla is QTEC30B. The borla has a different pattern than a standard 3 bolt header flange.
Old Jun 24, 2011 | 09:37 AM
schuz_GXP's Avatar
Well crap I ordered the summit brand 3" I guess I will see if it fits
Old Jun 24, 2011 | 09:40 AM
Quick Time's Avatar
Summit Brand is a Chinese knock off our unit. And they didnt do a good job either.
 Michael S. Palmer
Old Jun 24, 2011 | 10:40 AM
Question
So where is yours manufactured, then?
Old Jun 24, 2011 | 10:44 AM
Quick Time's Avatar
In our building! Hass VF-4.
Old Jun 25, 2011 | 01:49 AM
gocartone's Avatar
Should work, I have the QTP with the normal pattern and it fit fine. Not that the one made for Borla won't work better, but you should be fine with the one you ordered.
Old Jun 25, 2011 | 10:18 AM
regblkss's Avatar
I have the qtp on mine. Works great. Just opens and closes really slow.
Old Jun 25, 2011 | 02:02 PM
schuz_GXP's Avatar
Thanks guys it should be here Monday and I will let you know how it turns out.
