Stock exhaust
Old Jun 26, 2011 | 09:36 AM
Viper's Avatar
Question Stock exhaust
Does anyone know how to remove or install the stock exhaust in one piece? I'm thinking of going back to the stock muffler. I've had it in my garage for 8 years, but it's all in one piece (i-pipe and tips etc.) and wonder if you have to have a lift for the funny angle over the rear axle. I prefer not to cut it up and re-weld. Thanks. Thinking jack stands may not get it high enough.
Old Jun 26, 2011 | 02:53 PM
patSS/00's Avatar
If you take off the spring and shock and endlink on the passenger side, just using jackstands, the axle will hang down pretty low, seems like that would be enough space.
Old Jun 26, 2011 | 03:36 PM
94Z28-MSTGKLR's Avatar
It is, I've done it that way before.
Old Jun 26, 2011 | 05:02 PM
Viper's Avatar
Thank you
Old Jun 26, 2011 | 10:39 PM
garygnu's Avatar
thats how I removed the stock cat-back in one piece.consider installing a cut out for track use.
Old Jun 27, 2011 | 09:23 AM
omarrakeen's Avatar
yep i used that too. but on an electric jack it was pretty easy. X2 on the cut out. i miss the quite ride too!
Old Jun 27, 2011 | 10:52 AM
Starz T/A 17's Avatar
If your going to install a cutout you would probable be better off cutting the stock exhaust where you want the cutout before to make the install a little bit easier
