Reduce Solid Mount Vibration - Ideas?
If you're running a poly trans mount, switch to a stock rubber one; otherwise, it's deal with the vibrations, or switch to poly motor mounts.
The vibration isn't real bad, just enough to make the platic interior buzz.
Stock rubber is compliant to do what? - kill Noise Vibrations and Harshness!
Polly has most of the benefits of rubber without the flaw of being overly compliant.
Solid mounts suck for anything but a purpose built race machine. They amplify EVERYTHING, especially misfires and imbalances.
I've had all three and won't ever do solid mounts on a street / daily type car that I own again.
The vibration is at idle.
With the amount of good headers that aren't expensive for f-bodies, I can never understand the lure of slightly-cheaper, Chinese **** metal headers from ebay that never fit right and require a bunch of ghetto hacking to run.
