FAST Intake Gaskets
Old Jun 27, 2011 | 10:44 AM
themealonwheels's Avatar
Default FAST Intake Gaskets
I got a FAST LSXr 102mm intake for my car, but it didn't come with gaskets for the intake to head surface or the TB surface. I haven't read the directions yet, but I wanted to ask if this was typical.
Also, I saw on TSP that intake port gaskets for an LS1 are supposed to fit. Is that true? If so, Fel-Pro MS 92438 will be ordered
And finally, what gasket for the throttle body? I've got a GM pn 12576549 from a brief search, but is this the gasket that will work on the throttle body flange for the 102mm FAST? Thanks in advance!
Old Jun 27, 2011 | 10:48 AM
Jon@Texas-Speed's Avatar
On the cathedral FAST intakes, you should be able to move them over for the port seals. If you want to replace them, we have new ones on the shelf. The TB gasket should have been included. It is usually in the plastic bag of hardware that comes in the box.
Jon
Old Jun 27, 2011 | 12:39 PM
Jon
Thanks for the reply, Jon. I'll have to look in the hardware bag, but I don't recall a gasket for the throttle body opening. I bought the intake from a guy never used, but not unopened. If I don't find one, is there a replacement part number?
Old Jun 27, 2011 | 07:39 PM
bayer-z28's Avatar
It's normal for the 102 to not come with port seals. it does come with the TB gasket though.
Old Jun 28, 2011 | 07:55 AM
I'm almost certain previous owner of this never used intake has the TB seal, it's not in the box. Ordered GM pn 12576549, seal for an LS2 TB for GM intakes...
