Torquer v2
Old Jun 27, 2011 | 10:13 PM
majorityrls's Avatar
Default Torquer v2
Is stalling at idle normal with this cam? The rmps bounce from 500 to 1500 and every now and again it hits 500 and stalls. Also should mention that it has an aluminum flywheel.
Old Jun 27, 2011 | 10:26 PM
Gunrock_T/A_0811's Avatar
let it warm up a bit, is it tuned??? mine will stall when its cold if I put it in gear, i just give it a small amount of throttle to let it warm up. Takes about five min, then it idles fine.
Old Jun 27, 2011 | 10:28 PM
Steve Gunn's Avatar
It's not normal.I have an aluminum FW and don't stall @ an 850rpm idle... ever. You need more tuning.
Old Jun 27, 2011 | 11:23 PM
Big&Tasty TA's Avatar
Sounds like you need a tune
