Header bolt ?'s. Help quick!
Old Feb 28, 2004 | 05:46 PM
black_z's Avatar
Default Header bolt ?'s. Help quick!
As of now I have all the old exhaust off, and over half of the stock header bolts out. Should I reuse my stock bolts? Or use the pacesetters? Should I use loc-tite (blue) or anti-seize on the bolts? Thanks.
**EDIT** I used different keywords and found what I was looking for, mods you can delete. Thanks
Old Feb 28, 2004 | 06:09 PM
foff667's Avatar
LS1TECH Sponsor
i reused the stockers and cleaned the threads no locktight or anything on them though some do recommend it...just check them in a week or so to make sure they are still tight.
Old Feb 29, 2004 | 03:04 AM
eallanboggs's Avatar
Use Stage 8 and be done with it.
Old Feb 29, 2004 | 09:45 AM
Steve Burger's Avatar
LS1TECH Sponsor
Use the stockers and don't worry. I did and have not had them come loose.
Old Feb 29, 2004 | 12:12 PM
jamnut's Avatar
I used the Pacesetter Bolts, but that really doesn't matter. But I did use Anti Seize on my bolts. A metal bolt getting put in an aluminum head should get a little bit of anti seize so that the bolt doesn't gaul the metal when you are removing it. The anti seize may not help much, but it definatly doesn't hurt anything. I even use it on my spark plugs.
Old Feb 29, 2004 | 05:09 PM
Wesley SS's Avatar
I reused the stock ones I bought the Stage 8's but they didnt feel good going in and you may use some anit seize those bolts get really tight after a while.
