throttle response
Old Jul 2, 2011 | 01:52 PM
zayne0's Avatar
Default throttle response
whats up im runnin a 92 camaro with 5.3 swap and ls6 intake still working some bugs out trying to get it to go closed loop so i can do some efi live tuning. Anyways what can i do to get some better throttle response outta the engine? Ive got a cai and exhaust on the way, would like some input maybe on the tuning side to make it real snappy when i hit the throttle.
Old Jul 2, 2011 | 02:59 PM
crainholio's Avatar
Focus on getting the PCM into closed loop mode first, it's probably running in gimp mode using the low-octane spark table which would account for weak throttle response.
Once you get that done, there's usually plenty of gain to be had from both the high-octane spark table and the PE vs. RPM table. See the Tuning forum here for more detail.
Old Jul 2, 2011 | 05:05 PM
The_Bishop's Avatar
You need to get the speed density tables dialed in once everything else is right. Make worlds of difference in throttle response.
Old Jul 2, 2011 | 06:15 PM
zayne0's Avatar
awesome thanks, Im working on the closed loop problem, its kinda kickin my butt
