plug wire question
Old Jul 5, 2011 | 11:49 AM
BRIAN P's Avatar
Default plug wire question
98/ta... dumb question but i an doing full exhaust plugs wires and and motor mounts. anyways I have msd 8.5 wires and noticed (2) are slightly longer, where do these go? I am assuming the 2 longer go in the rear but figured i would ask.
Old Jul 5, 2011 | 07:46 PM
TankTheTurtle's Avatar
i just bought those wires as well, but I thought they were all the same length...
What part # did you get?
Old Jul 5, 2011 | 08:00 PM
Element's Avatar
On an LS1, it doesn't matter; they should all be (nearly) the same length.
Old Jul 6, 2011 | 06:02 AM
BRIAN P's Avatar
32813 part number. they are very close to the same length but 2 are a little larger. It looks as though it wont matter but all I know is the longer ones do not go at least on the pass. rear cause it will rub on side wall.
Another question is does anyone know if the steering linkage has a master spline? i marked the top but the bottom has me a little nervous. I would imagine it would but figured i would ask. thanks
