Engine block coolant drain plugs
Old Feb 29, 2004 | 10:54 AM
BBYZED's Avatar
Default Engine block coolant drain plugs
Where are they? The Haynes manual says below the exhaust maniflod, but I cannot see them. Or should I just disconnect the lower rad hose? Any help appreciated. Thanks!
Old Feb 29, 2004 | 11:56 AM
BB's Avatar
BB
Look from underneath the car. I can't remember exactly where they were. Seems like one was around the starter and one around the alternator.
Old Mar 4, 2004 | 09:12 PM
WILWAXU's Avatar
What are you trying to do?
Old Mar 4, 2004 | 09:34 PM
Mustang Hat'r 2's Avatar
Pull the starter and look streight up unless your blind you will see it. The other is behind the alternator on the side of the block vary hard to see.
