Need waterpump help ASAP PLEASE!!!
Old Jul 26, 2011 | 07:49 PM
kendogg's Avatar
Default Need waterpump help ASAP PLEASE!!!
OK, so I'm running a truck waterpump, and it has that outlet pipe at the top that comes out, up and towards the passengers side. Well, it needs to move. I heated the water pump outlet with a torch just a bit, got that pipe to turn, and then realized I need to bend it down too. However, now it's a little loose in that hole, def not as tight as it was before Is there anyways to seal it back up, and is there a replacement pipe from another vehicle that might work better? Or am I going to need to get a 1.5" weld-el and have it welded onto there??
Old Jul 26, 2011 | 11:48 PM
kendogg's Avatar
If anybody cares - we're just going to get an elbow welded to the top of the water pump, the size and direction I need it facing.
Old Jul 27, 2011 | 01:17 AM
99 Blue Bird's Avatar
that would probably be the easiest thing. good luck with your swap. ima have to check it out
