powerbond ud pully pin
Old Aug 1, 2011 | 07:12 PM
blkgagt94's Avatar
Default powerbond ud pully pin
so i bought a powerbond ud pully from vengeance racing
an it has the pin set up but didnt come with a pin so where do u git a pin at i dont need pin kit jut the pin
Old Aug 1, 2011 | 08:01 PM
S10xGN's Avatar
So...you're saying your crank has already been drilled for the pin? If so, just call Vengeance and ask for the size, then go to the hardware store and buy one. If not, then you'll need the kit.
Old Aug 1, 2011 | 08:04 PM
msydow's Avatar
i think you're talking about the notch for the keyway??? aftermarket cranks are usually keyed all the way to the end. a stock one is not so unless you are planning to underdrive a blower which i hope your not you dont need a key or pin.
Old Aug 1, 2011 | 09:56 PM
blkgagt94's Avatar
stock crank ud pully no blower
Old Aug 1, 2011 | 10:03 PM
LaBLKv6Z's Avatar
No pin needed, just seal up the notch with high temp RTV after you've installed the pulley.
By Brett Foote | 2026-06-04 05:00:17
