Oil Consumption
Old Aug 7, 2011 | 08:05 PM
PheonixLS1's Avatar
Originally Posted by LS1121
I personally don't have an issue with oil consumption, why I'm not sure but I and probably others would like to hear more on this vacuum reduction theory.
Indeed, how would you know how much to open it??
Old Aug 7, 2011 | 08:10 PM
ULTIMATEORANGESS's Avatar
ive never heard about this. who makes this part? looks like a simple fix for a PITA problem.
Old Aug 7, 2011 | 08:16 PM
LS6427's Avatar
This is interesting...thank you. This thread is actually turning into a USEFUL conversation. I personally don't have an issue with oil consumption, why I'm not sure but I and probably others would like to hear more on this vacuum reduction theory.
Its very simple.......from the factory the vacuum strength is ridiculously high through that intake port for the PCV system, thats it. Mine is still sucking very hard....but I have it set to about 1/3 - 1/2 its factory strength.
I just played around with it over a 2-3 week period till I found the setting where my oil consumption through my PCV stopped and when I kept checking for oil in my intake...there was zero......and I mean zero.
Old Aug 7, 2011 | 08:20 PM
LS6427's Avatar
Its an off the shelf plastic "T" fitting...then I put a torx screw into it that would screw all the way in and close off the flow. Then I backed it out till I started to feel suction get higher and higher.......then I played with it till I was happy and my engine was happy.
Its been like this for about 5 years now. My crankcase has plenty of evacuation suction without any oil going through. No need for a catch can.
Also....that line from that vacuum intake port is sucking crankcase gasses from my passenger side valve cover port, I have my LS6 valley cover capped off. The LS6 valley cover is TERRIBLE. It allows way too much mistified crankcase oil to be sucked up though that vacuum line. The valve cover is much better because the oil in there is flowing, not a mist.
Old Aug 7, 2011 | 08:35 PM
LS1121's Avatar
That's what i was thinking, many people have busted my ballsover this LS6 valley cover,They think it is soooo great but it still gives the motor the same acess to oil as mine. So what is the big deal about this cover, it just uses less fuel line? And.......it cost a ton of money to have someone install the thing after you buy it.
Old Aug 7, 2011 | 08:46 PM
LS6427's Avatar
OH..............I also did away with my factory system and just put an air filter on my drivers side valve cover. So I get fresh air sucked into the drivers side valve cover and that fresh air gets sucked all the way through the crankcase and up into the passengers valve cover......then into the intake.
But still...to keep the factory PCV system the way it is.....that vacuum strength needs to be cut in half from that vacuum port.
Old Aug 9, 2011 | 08:00 PM
91lxstang's Avatar
Originally Posted by PheonixLS1
Actually I guess you are blind cause the OP said 1500 miles and 1 quart of oil. SSSOOOOO if he has a heavy foot, as the supporting document states, he will burn up more oil than the acceptable rate of 1 quart per 2000 miles. That means every 500 miles is 1/4 quart, break that down to the 500 miles missing to get him to 2000 miles ( as he stated he is at 1500 ) he is consuming 1/3 quart per 500 miles. Which would in fact be within the peramitters (spelling) of the supporting document if he has a heavy foot. So you may not be blind or stupid, you just cant read and then you try to bash me when I present black and white fact. We don't know his driving habits, we can only assume from the numbers he gave us to fill it into the equations presented by GM's document and go from there. COULD there be something else going on?? Sure, but why have somebody waste their time and money throwing "suggestion" parts into the car. Have a machanic properly diagnose the car and see what you find instead of playing the guessing game, it may just indeed boil down to normal consumption. Also keep in mind that if he has an M6, the supporting document also states that if he drives aggressively ( i.e. engine breaking and rpms 3000 to redline) that he can consume 1 quart per 500 miles!!!! Well holy sh&t, lets change your PCV system, all your gaskets, your oil pump, pull your TB, hell rebuild that whole ***** ***** just to find out there was nothing wrong. Well YEE HAW!!!!! (sorry for the rant lol) Not trying to be an *** but read the whole document before you "rebuff" me as you put it. Its all there in plain ole black and white.
Oh is my foot ever heavy. Thanks for all of your help and useful info. I really do appreciate it. I will be doing a catch can soon.
