What mods next? NEW to LS1
I must say it feels so much more "Potent" than my 96 Lt1 trans am.
Current mods done are :
1.true duals (which i need to sort out because they are just too low down and hit on every speed bump here in Mexico, of which there are loads!).
2. Z06 cam, not much over stock, but good for 15hp apparently (have been advised this is closer to 30hp.. woot!).
3. LS6 timing chain and oil pump
4. egr removed, air pump thing gone...
5. Air conditioning disconected, drive belt removed.. (have to sort that out as im cooking in the sun)
6. Free ram air mod,
7. think the throttle body tube has been cut back as I dont see it sticking down when I open the blade manually and look.
8. 3.73 gears
A few other things that I am forgetting,
I am thinking of getting a tune as a "base" to see what is my starting point and then going from there, any tips would be greatly appreciated.
regards.
G.
Also, I read a thread on the vette forums about a relocation kit for the Oil pressure sending unit, would this also work for me? It would be nice not to have the sender hidden at the rear of the intake manifold as its a royal pain in the backside to even get my hands in there.
If you can't swing that.... Ls6 intake/ported TB/lid (if you don't have them already, I have a lid FS if interested) MAF and a retune.
If you go back to an ORY make sure you get a good merge (flowmaster) and a 4" pipe with a cutout before reducing back down to 3".
