Underdrive pulley removal?
I'm next. The new oil pump is on it's way. Hope I have the same result.
Mine has only 1100 miles on a blueprinted pump. I don't think that it ever worked correctly.
The balancer is a March from the batch which had extremely tight tolerance.
Good thing the install tool used a threaded rod with aircraft quality washers. The March was so tight that I bent several washers before the balancer became seated against the crank.
A couple of shots of nitrous to the crank snout should allow the balancer to slide off using the correct tool.
As 01ss mentioned...
this is a set, but you can prob find a more robust puller on this site
http://www.harborfreight.com/4-piece...set-40965.html
https://ls1tech.com/forums/generatio...ud-pulley.html
