what next? max effort 346
Old Aug 14, 2011 | 05:32 PM
Mike Morris's Avatar
I like the worked Ai heads better than aftermarket heads because they are lighte,cheaperr and perform the same as a AFR and TFS offerings while still using your stock rocker arms or upgraded stockers.
Fast 102 has been proven on stock internal cars so with a head/cam car its a no brainer. If he wants max effort its the best to go with n/a ported by Mamo
Old Aug 14, 2011 | 06:53 PM
LilJayV10's Avatar
Mamofied AFR 215's or worked TFS heads by TEA or something from WCCH. Run as much compression as you can, cometic head gasket to increase quench.
Ported FAST 102/102 w/ Chris1313 ram air or Fast Toys bigger ram air.
Cam matched for your setup, might have to fly cut.
EWP, bigger headers with good y pipe/merge,UDP
