Ls2 intake on a ls1???
Old Aug 23, 2011 | 03:03 PM
bottlefed01z28's Avatar
Default Ls2 intake on a ls1???
Ok I have set of ported ls1 heads I have a ls6 intake on it for now I was inking of going 102 but it's sooooo much money I was thinking of possibly going ls2. I have fast fuel rails and all braided fuel lines upgraded injectors. My question is will a ls2 fit on my heads and if they do will I need to do any other upgrades. Besides a throttle body
Old Aug 23, 2011 | 03:09 PM
redbird555's Avatar
Being that you have an 01 z28 you already have an ls6 intake from the factory. Putting on an ls2 intake work work but you'd actually be losing power because it is very poorly designed. The only step up from yours now would be a fast intake. If it's just a bolt on car the fast isn't worth it because it won't do much for power. If you plan on a cam to go with the heads then the fast is a must
Old Aug 23, 2011 | 03:10 PM
Mike454SS's Avatar
LS2 intake will fit your heads, but you may find it is a bit lackuster in gains...there are some manufacturing problems that those manifolds were plagued by...mostly becoming evident in leaks between runners...they can be repaired, and they can be a decent intake afterwords, but it's not the most straightforward thing to do.
Old Aug 23, 2011 | 03:12 PM
Mike454SS's Avatar
It's not really the design of the LS2 intake, it's the manufacturing...but yes...if you're not repairing that...the LS6 is a better setup.
Old Aug 23, 2011 | 03:14 PM
actually its a ls2 forged bottom end with ported ls1 heads but from what u r saying it sounds like i need to go fast ugh.
Old Aug 23, 2011 | 03:21 PM
Capricio's Avatar
Good news is you can probably sell the LS6 intake to any 98-00 owner for just under half what you'll need for the FAST.
Old Aug 23, 2011 | 03:32 PM
ok so if i get the 102 intake is it worth it to get a 100 maf even though i have an 85? and also is it worth it to get a larger lid?
