PVC catch can reservoir
Old Mar 5, 2004 | 05:06 PM
2000Firehawk's Avatar
Default PVC catch can reservoir
DON'T TO IT.....
The reservoir collapsed...
There is so much suction from the engine, that the
reservoir now looks like a prune, & it torn open a
seam...
Dave
Old Mar 5, 2004 | 05:31 PM
Mike02Z's Avatar
Which Catch Can did you use? This is the first time I've heard of this happening. That sucks dude.
-Mike
Old Mar 5, 2004 | 05:41 PM
98sspullin'em's Avatar
was your made out of plastic? mine is made of a thick glass and I have never had any trouble with mine... i posted pics a while back...
sorry to hear you had a hard time
Old Mar 5, 2004 | 07:28 PM
1999Daytona500PaceCar's Avatar
You can use PCV - but just not the usual stuff. I found out too how much suction there is in the system when I used a rather strong plastic canister that collapsed almost immediately.
The piece of PVC I am using is a joint that is straight - but threaded on the outside on on end. It is made pretty thick and has about a 3 inch Outside Diameter and is about 4 inches in length. I used a PVC "plug" plug on the un-threaded end and made that the bottom side - and screwed a rounded cap on the threaded end as the top side. I then tapped 2 of the neccessary fittings into this cap for the in and out hoses. I can simply unscrew the body from the top cap to empty. It tucks down behind my battery nicely and since it is white (white car) it doesn't stick out at all and I ran the hoses to where nothing looks out of the ordinary. All for less than $15 including extra hose and fittings. It's worked very well so far...
Old Mar 5, 2004 | 07:38 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
If you use a decently thick metal there would be no risk of collapse or melting.
Old Mar 5, 2004 | 08:01 PM
I was trying to use the stock rad overflow reservoir..
Dave
Old Mar 5, 2004 | 09:27 PM
Country Boy's Avatar
Senior Member
Dave
I seen the write up on that and it looked good...... I dont guess it it worked as good as it looked
