new header questions
Old Sep 7, 2011 | 05:38 PM
goinbroke09's Avatar
Default new header questions
i just bought some bbk headers and y and had a few questions
1. what do i do about the rear o2s? extend em and put em in?
2. bbks come with wire to extend the o2s, anybody cut theirs and done this
3. since i wont be running an air pump either can i drive this for a bit after i install them?
thanks alot for any help
Old Sep 7, 2011 | 06:50 PM
matt224's Avatar
I would remove your AIR pump first; there is a guide on here and its fairly easy to do.
I also have BBK's and I bought a pair of 02 extensions from ws6store for the front 02 sensors. The rear passenger 02 sensor can still reach the BBK y pipe's bung with no issue, but the driver side cannot. I bought a drain plug and fiber gasket to plug up the unused 02 bung. I'd definately get a set of 02 bungs, it makes life a lot easier than having to splice into your existing 02's.
Old Sep 7, 2011 | 07:55 PM
LS1WS6dreamer's Avatar
I am going to get some BBK's, but I was thinking they had the front 02 holes and there was another spot for a wideband. I am going to run the Bosch 13111's, but the extensions do work well for a lot of people. Splicing them poorly can result in 02 issues. Read a thread where a guy spliced his and was getting a buncha codes. Broke down and bought some extensions and bam! everything was OK. Just depends on how good you are at wiring I guess????
I wouldn't think its that hard, but I just don't feel like screwing with it. Plus one of my 02's has 160,xxx miles on it.
remove the air pump. Doesn't really take that long. Or it didn't on my 98.
Old Sep 7, 2011 | 08:50 PM
thanks guys im ordering the ws6store extensions tomorrow but what did you do about the rear driver side? just plug it with an oil drain plug?
Old Sep 7, 2011 | 08:56 PM
matt224's Avatar
Yep.
I bought this plug:
https://www.belmetric.com/dp18x15-p-...s0&cPath=11_90
and this gasket:
https://www.belmetric.com/g18-p-551....s0&cPath=11_93
Perfect length and no leaks at all.
Old Sep 7, 2011 | 09:11 PM
what did you do as for a tune missing one o2? i know they tune those out but it's gonna be while before i can have it down long enough to tune. thanks again man
Old Sep 7, 2011 | 09:27 PM
matt224's Avatar
I don't have mine tuned yet and its been a couple weeks. It shouldn't cause a problem, but your engine light will be on
