427 with 1 Probelm...wont start HELP!
If it is not the battery (you tried a known good battery, right?) and not the connections from the battery to the starter or the engine to ground, the only thing left is the starter itself. When you connect a battery charger, you have serious current available to run the starter and everything else.
Have you checked the supply voltage to the pcm and injector fuses while cranking from one battery?
Check all your connections including the grounds and try it again.
Also, like OldCobraGuy said, there is a relay in the circuitry somewhere. I am not familiar with that part of the circuit either.
Hope you find the problem.
