What could be causing this?
Old Mar 6, 2004 | 04:44 PM
1RawTA's Avatar
Default What could be causing this?
Well today i put my ECS ported TB in, i also did the coolant bypass why i was at it.. now that it was in and the roads dried up a bit i took it out for a test spin.. i dont know if it is was doing it before the TB, but the car hesitates a little more in first gear when i hammer it from a idle roll. but if the car is over 2000 rpm just cruising along at maybe 10mph it goes fine. could it be the TB?
Old Mar 6, 2004 | 11:41 PM
lsx24's Avatar
I would check the TB action when you open it from closed position.
Old Mar 7, 2004 | 09:02 AM
1RawTA's Avatar
well there is a little slack in the throttle cable, but i think that is normal
Old Mar 7, 2004 | 11:11 AM
lsx24's Avatar
If there is hesitation in initial opening, it may cause a delay.
