How do you think this happened?
Old Sep 15, 2011 | 09:29 PM
Slash8915's Avatar
Default How do you think this happened?
Long story short, These are some Hookers that are pretty old. I noticed a weird sound coming from under my hood so I checked, and fire was shooting out towards my motor. I took off the Headers and here's what I saw. How in the hell do you think this happened?
[/QUOTE]
Old Sep 15, 2011 | 09:37 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Is the edge of the opening rusty?
Did the weird start very suddenly or did it build up from normal over time?
Old Sep 15, 2011 | 09:41 PM
Slash8915's Avatar
No rust. I really don't know. Strange thing, is it's the exact same size as the "Hooker" emblem on the other header, but the hole is on the inside.
MeentSS02's Avatar
Kleeborp the Moderator™
Holes in header primaries are usually caused by emissions fittings that fatigue and fall off...if there was an emission fitting there (AIR or EGR), then that's what caused it. Otherwise, I have no idea.
Old Sep 15, 2011 | 09:43 PM
msydow's Avatar
way to lean?
Old Sep 15, 2011 | 10:00 PM
Trans24am's Avatar
might of been to lean
also could of been a weak spot in the metal and just over time after the pipes heating up and cooling off probably had a lot of wear on that one spot and it prob started as a little hole but as air passed through it got bigger
Old Sep 15, 2011 | 10:06 PM
projectX's Avatar
Damn thats not good
Old Sep 15, 2011 | 10:28 PM
ls1ya's Avatar
Probably a weak spot in metal or the emblem is conducting or retaining heat in that area.
 Michael S. Palmer
Old Sep 15, 2011 | 11:05 PM
Slash8915's Avatar
When we tried pulling out the driver's side header, we cut off the collector at the end. As soon as the collector was off, one of the primaries actually completely fell off of the header. Lol
Old Sep 15, 2011 | 11:45 PM
01ssreda4's Avatar
This, that was the spot for the EGR tube most likely. Very common failure point.
Old Sep 16, 2011 | 01:45 AM
whatsa347's Avatar
Dude with all the heat lately around here I would bet it had something to do with it, My rotors warped recently because of all the heat with actually a chunk of metal came off when pulling them.
Old Sep 16, 2011 | 02:04 PM
cyipher's Avatar
Header wrapped?
Old Sep 16, 2011 | 06:28 PM
Slash8915's Avatar
Originally Posted by cyipher
Header wrapped?
Nope.
Old Sep 16, 2011 | 06:36 PM
HotRodKid's Avatar
Im going with the idea that the hooker emblem fell off and took some tubing with it due to the weld cracking along its outside edge.
Header companies usually label BOTH headers in a set, so i highly doubt an EGR port fell off and left a hooker tag sized hole
Old Sep 16, 2011 | 06:49 PM
Bluestreak's Avatar
+1. This happened to my 11-year old Grotyohanns earlier this year. It cost $265 to have them cleaned up, the old emissions fittings closed off, had some welds strengthened, re-coated, and back on they went.
Old Sep 16, 2011 | 10:21 PM
01ssreda4's Avatar
Some of these answers in this thread are plain silly
My air fitting was cracked (Hedman LTs) when I bought the car, then it started to open up further so I cut it off and welded a piece of sheet metal over the hole. Never had another problem out of those headers after that.
Old Sep 17, 2011 | 05:18 PM
K9Kev's Avatar
" Old Hookers ".....
Should never be used again. They are simply to tore up.
Can't believe no one else threw this out here
