Vic Jr intake help
Old Sep 18, 2011 | 08:47 PM
98SLPss's Avatar
Default Vic Jr intake help
Where do you get the vacuum for the brake booster when you install a Vic Jr intake on a 00 camaro Ls1?
I used the brass fitting that is on the intake that is below the elbow for the MAP sensor? Is that right?
Old Sep 19, 2011 | 05:02 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The small fitting on the side of the intake is for the MAP, you'll have to find a 90* fitting to go on the #8 runner for the brake booster line
