102mm TB, throttle cable problem
Old Sep 19, 2011 | 06:32 AM
Flamed99Z28's Avatar
Default 102mm TB, throttle cable problem
So I'm trying to get my throttle cable adjusted correctly on my 102mm PTM TB going on my FAST 102. I have the cable in the bottom hole on the TB cam, but it won't close fully unless I push it closed by hand. In the traction control module (right by the battery) when I close the tb pulls the bottom gear off of the green spacer that stops the bottom gear. I've tried pulling on the cable with the adjuster loose to get a little more length but it just doesn't appear to be there, it's like I need a cable 1/4" longer.
Does anyone have any ideas?
Thanks for any help or ideas, I found a similar issue with the search feature from last year, but there was never any solution.
Old Nov 17, 2011 | 02:29 PM
ska4life07's Avatar
same problem here
Old Nov 17, 2011 | 09:54 PM
ska4life07's Avatar
Are you using a spacer for some reason? I believe that's my problem because it adds a good inch and then the the cable can't quite reach far enough for the tb to close all the way.
Old Apr 13, 2013 | 08:59 PM
Sleeper S10's Avatar
How did you correct this, I have a spacer to connect my 92 MM tb to Fast 102.
Cable is short also.
Old Apr 14, 2013 | 04:26 AM
Exidous's Avatar
Does your PTM TB not have two positions to mount the cable? There is another on mine that would allow for a cable that is about a 1/4" shorter.
Old Apr 15, 2013 | 08:40 PM
It does but I'm still out of luck.
The throttle cable length was fine before the 92 mm tb to Fast 102 intake adapter.
Guess I will have to try the Lokar cable.
Old Apr 15, 2013 | 09:08 PM
studderin's Avatar
I ran into that on my 102TB, running it on some different style intakes. And some I had to make a bracket so my stock cable fit. I didnt want to get a difrrent cable, or make a stop on the gas pedal. Ended up I just drilled some extra holes in the TB. I have 5 total, I got 1 or 2? between the stock ones (98-00 or 01-02 Tb cam shape, and cable setup) worked good for me move to a new hole for WOT.
I posted some pics in some other thread, and my build thread this year
