Need HELP NOW....my SS is stranded!
The dealer replaced my lock cylinder and the BCM for about $500. I was pissed.
You can't push start it and the starter is fine....the BCM is preventing the car from starting...sorry, but you're out $500 unless you are under warranty.
I had exactly the same issue last year. It wouldn't start - I'd try to turn the key a few times - and magically it would start. In a couple days the problem got worse, so I had to push-start it couple times (M6). Eventually stopped by the dealer. They scanned it and told me the sensor in the key master cylinder was bad. I need the car everyday and so I just had them fix it (replace the cylinder and get the new keys. they told me the sensor alone couldn't be replaced and I had no reason to doubt that, though still don't know) . $460 for everything or something like that
If you have time, you may try to fix it on your own - you have to disassemble the steering coulumn, and the cylinder is somewhere under the airbag... ..perhaps the stupid sensor has a loose wire or something like that, and you would save the labor money.
This is the cheap and easy way. However, someone can steal your car with a regualr key.
Do you have a digital ohm meter?
BCM failure, no don't attempt to repair, you need to reprogram the vats to the specfic set up.
However they are rare, & are most likely sold as a inexperenced tech throwing parts at a problem IMO.
I am...just plain lost. I have been doing searches on every damn fbody site on the net! My car is a 98ta, I just installed pacesetter headers,ory, and a 3500 tci stall. Also removed air,and egr, no rear sims because texasspeed is gonna flash the pcm. I havent touched the car in 2 days, went outside and it started up on the 1st try as usual. Well 2 cranks later did it again. I did a fuel pressure check on the rail and it was fine. Removed or swapped relays,fuses. Checked the grounds on the block. Oh my brand new ngks are straight black and smell like gas. My car will attempt to crank, fuel pump comes on pressure is good, turn key car cranks away, no its not the starter. Floor the car and it sputters and starts vvvvvrrrrrrrrooooooom. Idles fine,drives fine wot fine. Wtf could cause this at start up? The car is absolutely flooded after 3 starts, what give what did you guys come up with?
I have checked over everything what could I have missed? This is pissing me off like no other, I dont want to just start throwing money and parts at the car. I'm gonna swap the plugs tomorrow, and see what else I can find wrong. And no I do not have access to a programmer or edit. But the codes I am throwing are egr,air, and coolant temp sensor, I replaced the cts after the headers because the pin broke. I have no rear o2s or sims, and the car has not thrown a cat or o2 code, wtf
