Recommended OEM size ORY
Old Sep 24, 2011 | 05:55 AM
ls1owner4life's Avatar
Default Recommended OEM size ORY
Hey, I want to install an ORY on my stock 02 camaro. What brand you would recommend with best overall quality, hardwear, and most importantly ground clearance. $$$ is not an issue and I can't have LT's(CA). Im looking to increase the volume of my exhaust(not hp) with the stock SLP CME muffler package.
Thank you for your help
Old Sep 25, 2011 | 08:32 PM
Bump
Old Sep 25, 2011 | 08:43 PM
TransAmWS.6's Avatar
I have the Stainless Works O/R Y on my SS, running it through the stock manifold's/catback for now and it's been fine. It's pretty much a direct replacement for the stock catted Y. Expect a good bit of rasp once you switch over though.
Old Sep 27, 2011 | 08:54 PM
2000PewterT/A's Avatar
There are a bunch of different ones out there, if I were doing it I would spend a little extra money and get some headers got complement the ORY, its worth it in the long run because if you ever upgrade to headers then you will have to buy a new ORY or build a custom one to adapt the one you already used with the factory manifolds. I have a TSP ORY, really great fit with my lts.
