texas speed header fitment and install
Old Apr 8, 2012 | 04:00 PM
  #101
mikh338's Avatar
Originally Posted by Mike Morris
Upgrade your motor mounts and that won't be an issue
ok great, im getting ready to do polys anyways so thanks for the info!!
Old May 9, 2012 | 01:31 PM
  #102
my_99Z's Avatar
Hey guys had a question. Do the TSP long tubes come with AIR Or EGR ports? I'm in California and am trying to stay within smog regulations so I don't have to go changing everything every time I need a smog.
Old May 9, 2012 | 01:49 PM
  #103
Latch's Avatar
They do not have AIR or EGR, but that's irrelevant since any long tube header will fail in California.
Old May 9, 2012 | 01:59 PM
  #104
my_99Z's Avatar
I've heard of quite a few people being able to run LT headers and being fine with emissions in California. I bought a set of Used SLP headers but im not sure I'm going to like them because my car is lowered and I didn't look into that before I bought them. Tying to find something that will replace them and still have the AIR and EGR ports
Old May 9, 2012 | 03:28 PM
  #105
andy-lswon's Avatar
What's the GM part# for a new set of stock motor mounts. If I do replace them its gonna be with a new set of oem ones
Old May 9, 2012 | 05:56 PM
  #106
Stippy17's Avatar
Just buy a set of replacements from your local parts store or online. I bought a set made by Anchor.
Old May 19, 2012 | 08:32 PM
  #107
mikh338's Avatar
hey guys so got the polys all done what a *****!!!! going to install the 1 7\8s tomorow, now i have the steering knuckle removed no way i was getting my old headers out without that being apart. i keep seing people say you have to undo driver motor mount and raise the motor. i will never touch those again LOL. i will sell my 1 7\8s and put the 1 3\4s back in if thats the case. but then i see people say they didnt have to touch the mounts. whats the deal?
Old May 19, 2012 | 09:06 PM
  #108
sjsingle1's Avatar
stop whining and do the poly mounts already........dont be a *****
Old May 19, 2012 | 09:11 PM
  #109
mikh338's Avatar
me? i did the poly mounts finished them today. not looking to take them back out to do the 1 7\8s id rather put my 1 3\4 back on. it was an absolute nightmare. planning on doing a 408 build this winter so if thats the case ill just save the 1 7\8s for that time...
Old May 20, 2012 | 12:30 AM
  #110
Stippy17's Avatar
I didn't have to touch my steering knuckle, and I didn't have to remove drivers mount, or raise motor.
These are the easiest set of headers I've ever installed. I have no idea why some people are having all sorts of problems.
Old May 20, 2012 | 07:56 AM
  #111
mikh338's Avatar
those are words of encouragemnt lol, i will be starting them in about an hour. when removing the 1 3\4 i only had to remove the steering knuckle, the car is so high in the air they can slide up and in vertically which is the easiest way to do them.
Old May 20, 2012 | 08:13 AM
  #112
got milk??'s Avatar
Every car is alittle different, my passenger side went in smoothe. Driver side had to have everything come out before they wanted to go in. I didn't do my install with oem motor mounts, so maybe because the polys are slightly larger the other stuff has to be moved. Who knows I would just be prepared for a nightmare and then when its easy you can get to sooner!
Old May 20, 2012 | 08:48 AM
  #113
mikh338's Avatar
did you have the car high enough in the air? i think thats a lot of peoples problems. if its high enough, you should be able to sldie the headers in straight up in. well im about to find out off to work on them ill post back later with results!!
Old May 20, 2012 | 09:04 AM
  #114
got milk??'s Avatar
Had it as high as I could get on 6 ton jack stands. On my install it wasn't about sliding the headers strait up, it was one of the header tubes making contact with my motor mount. I removed pacesetters during the install and those litterally fell off when the last bolt was gone. The driver side slid right out! and would go back in, I could install those all day long without removeing anything additional. My driver side TSP 17/8s were slightly different. One of the tubes was routed different than the Pacesetters and thats what made it a PITA. I hope your install goes smoothe like the other person posted, I really do because like you I aleady had my poly mounts installed and had to remove the driver side to get these larger headers on and then wrestle the motor back on the mount!
Old May 20, 2012 | 06:36 PM
  #115
mikh338's Avatar
well i hate to say it but you were right. i couldnt get the driver side in without removing the mount. the pass side went in like cake. so i just ended up putting my PC 1 3\4 back on. i will save the tsp 1 7\8s for this winter if i do my 408 build or i iwill sell them i dont know yet but i was very pissed off lol. i didnt want to deal with the mount again either. but got all new gm header gaskets and gm header bolts with the msd wires on. also had to replace my driver side coolant temp sensor as i broke the plastic plug off it somehow during the install. also driained all my oil and filter that had about 1000 miles on it to get the 1 7\8 header in to find out it still wasnt going to go in, so just another kick in the nuts. drove it down the street to a friends garage with open headers to start doing the 3 inch duals with x pipe thru my tunnel brace which is going to suck ***** to find out that he had nomore wire left in his mig machine. at that point i was so pissed off i said **** this and took the car back home and parked it. next weekend we will get the exahust done i hope.
Old May 20, 2012 | 06:45 PM
  #116
Blu99T/A's Avatar
Just got mine all buttoned up today TSP 1 7/8" SS headers, TSP SS Y-pipe with FM 3">4" merge, single custom 4" exhuast with a Hooker Maxflow dumped (similar to the mufflex). I am very happy with the setup.
Old May 20, 2012 | 09:05 PM
  #117
mikh338's Avatar
way to rub it in reallllyy nicccee...haha jk man, thats great. guess i will have to wait for the 1 7\8s to be installed.
Old May 20, 2012 | 09:22 PM
  #118
z28241's Avatar
I had to bang up on the floor boards on drivers side to get it in, yes I had it on a lift..steering knuckle removed as well.
Old May 21, 2012 | 12:44 AM
  #119
Stippy17's Avatar
Yup did mine on a lift. My pacesetters slid right out, and after I replaced my motor mounts with OEM mounts (driver mount was ripped) the new TSPs slid right in. Didn't have to remove anything special except for the drain plug, filter, and plugs/wires.
Wasn't hard, and I'd do it again for a buddy if they asked me to help.
Old May 21, 2012 | 02:07 PM
  #120
mikh338's Avatar
so it seems to be the difference in having stock mounts or the poly mounts, when getting these headers to fit. i really didnt think they were that much different in size? live and you learn i guess, i will know next time. hopefully this winter i will be doing a tubular k arm anyways and possibly going more cubes so i will have everything pulled again anyways
