Blinking SES light? Car running rough...help!
Old Mar 8, 2004 | 07:31 PM
BlackBootyZ71's Avatar
Default Blinking SES light? Car running rough...help!
did the header install saturday, and installed some TR6's gapped at .035 (for the impending blower install).
The car is running open headers, and i need to take it to a shop, but the SES light is blinking?
But aside from that it's running rough as hell, vibrating the crap out of the car!
I have to drive the car about 35 minutes tomorrow to the exhaust shop...how worried should i be? Could it be that the car is in serious need of a tune after the colder plugs???
Thanks,
Mike
Old Mar 8, 2004 | 07:34 PM
Griswold's Avatar
A blinking ses light usually means a misfire. I would check all the plugs and plug wires. It could just be a loose wire
Old Mar 8, 2004 | 07:36 PM
EVIL's Avatar
coulda cracked a plug.
i wouldnt run open headers too long, it will mess the o2's up.
Old Mar 8, 2004 | 07:38 PM
FatZ28's Avatar
Check plugs and wires...also get the codes scanned to see if it might be a bad 02
Old Mar 8, 2004 | 07:39 PM
SSmokin 01's Avatar
Thanks,
Mike
A flashing SES light is miss-fire/fires. Check to make sure all of your wires are connected. Should hear/feel 2 clicks from wire to coil pack and 1 click from wire to plug. Also if for any reason you removed your coil packs make sure the ignition harness has been re-connected to them.
Did you check all of the gaps on the plugs before installing them?
Old Mar 8, 2004 | 07:40 PM
ss rally red's Avatar
My bet is plug wire not all the way on plug or coil pack. Post up when you find out.
Old Mar 8, 2004 | 08:13 PM
ok, i'm getting ready to go check all of the plug wires...I don't have ATAP with me, so i can't scan for codes....
I (like a moron) didn't pay attention to which coil pack came from where, or which wire came from where...thinking that they were all universal...could that be the problem?
Are the individual coil packs marked? do they need to be in a certain order?
Thanks again, i really appreciate it...i'm running out of time!
Old Mar 8, 2004 | 08:26 PM
FatZ28's Avatar
I do believe the coil packs do need to go in order but the plug wires do not matter. Go to autozone they will scan it for free.
Old Mar 8, 2004 | 08:33 PM
well, i (again like a moron) didn't plug in the main harness for the coils...on the passenger side....plugged it in and no more blinking light (it is still on, but the AIR tubes aren't connected) The car is running a TON better now!
Evil, I'm just heading from Burtonsville up to FBC, Tyson is going to try and piece together this y-pipe that I couldn't get together. (i swear, i think they sent me the wrong piece).
Thanks again for all of your advice, I really appreciate your willingness to help out!
As for the coil packs, i'll have to figure that out..the car seems to be running fine now, but i'll scan it and see what codes i'm getting.
Thanks again.
Mike
Old Mar 8, 2004 | 08:57 PM
SSmokin 01's Avatar
Thanks again.
Mike
I had a feeling thats what it was by how rough you said it was running. The SES light is still on most likely because your rear 02's aren't hooked up. If you don't plan on incorporating the rear 02's in your set-up, 02 simms will take care of that.
It also doesn't matter which coil pack is where. They're all the same.
Old Mar 8, 2004 | 09:06 PM
I have 02 simms on the car now, but will soon be getting all of the codes deleted
I'm thinking it's the AIR tubes not being connected...does that make sense?
Old Mar 8, 2004 | 09:32 PM
SSmokin 01's Avatar
I threw an SES light even though I had the simms. I had to clear the code twice before it went away. Just curious, why haven't you connected the air tubes?
Old Mar 8, 2004 | 10:04 PM
because they were being a bastage and wouldn't bolt up. I'm in between on whether I should just block em off and scrap the whole system.
Old Mar 9, 2004 | 01:21 AM
slik98z's Avatar
after installin the simms, if the light was on it will take a 50 miles for teh compute rto test the system to see if its a closed system. it seemed like it took forever for my ses light to go off after removing the cats. but it goes off, if you're air tubes aren' thooked up it will throw a code i've found. did you get flowtech headers? i've heard of them having issues with the air tubes pointing in the wrong direction, the air tube can be moved around a little with some force just be careful not to bust it off.
otherwise just put block off plates and eliminate the entire system, save some weight just make sure when you go to get your emssions testing in md you go to a place u know isn't gonna look under the hood. if you aren't sure about it, i gotta buddy that works in frederick md, he'll do your emissions and inspection if they are stingey near you.
Old Mar 9, 2004 | 11:08 AM
i have the FLP's...I'm just going to go with a blockoff plate and take out the system...I appreciate you offering up your buddy, but I think I have to get emissions done in Montgomery county (since that is where the car is registered)
Old Mar 10, 2004 | 01:00 PM
14u2nv's Avatar
Could it be a bent pushrod or several bent ones? When I mis-shifted at the track with my SS when I first bought it back in MAY 1999 the SES light came on and continued to flash. The engine ran extremely rough and ticked very loudly. I don't remember the exact code the PCM was throwing but it did have a mis-fire code I do remember that. I pulled the pushrods and I had three bent. One of the pushrods was bent like a "Z" and the other two were slightly bent. The one that was really bent had elongated the hole in the cylinder head where the pushrod goes through. Get yourself a piece of glass and remove all the pushrods, keeping them in order so you can replace them in their exact place. Roll the pushrod back and forth on the glass. It will be easy to tell if it's bent or not. If so...the OEM replacements are under $20.00 each but you may want to upgrade them.
Old Mar 10, 2004 | 02:14 PM
thanks for the reply, but see post #9
