bank 1 sensor 1 code
Old Oct 6, 2011 | 09:03 PM
lippies's Avatar
Unhappy bank 1 sensor 1 code
this is my main problem with my 02 sensor and i cant fix it. i changed spark plugs, wires, 02's,fuel filter and i still seem to have a boggy idle. any help please?
Old Oct 6, 2011 | 09:24 PM
Darkman's Avatar
What is the code number?
Old Oct 6, 2011 | 10:09 PM
lippies's Avatar
i had two codes. p1133 and p1153. idk what else to do. i tuned out my rear 02's and a week later i got these two codes. there on for a week and come of for a day or 2.
Old Oct 6, 2011 | 10:30 PM
WonBadZ28's Avatar
mine does this too....cant figure it out...subscribed
Old Oct 7, 2011 | 06:04 AM
Darkman's Avatar
The two codes indicate issues with both front O2 sensors. Once O2 sensors are contaminated they can continue to throw these codes even if the original cause of the contamination has been remedied. The problem can also be with the wires and/or connectors in the O2 sensor circuit, but with both codes present the primary suspect becomes the connection of that wiring harness at the PCM. See attached.
File Type: pdf
Old Oct 7, 2011 | 08:12 AM
omarrakeen's Avatar
join the club. having bank 1 and 2 both after long tubes. tried swaping rear for fronts and nothing. car runs great tho
Old Oct 7, 2011 | 08:29 AM
Darkman's Avatar
Did you have it tuned after installing the headers?
Old Oct 7, 2011 | 11:25 AM
omarrakeen's Avatar
nop, tune is really costy here so am saving it for the cam
 Michael S. Palmer
Old Oct 7, 2011 | 04:43 PM
lippies's Avatar
I had it tuned after the Bosch 02's, and after installing the complete exhaust system. Feels like mines running a little night at idle.
