3" Y pipe vs 2 1/2" Y pipe???
Old Oct 19, 2011 | 01:21 PM
30th t/a's Avatar
Default 3" Y pipe vs 2 1/2" Y pipe???
Is there any advantages to having a 3” Y pipe that merges into a single 3” intermediate pipe vs a 2-1/2” Y pipe that merges into a single 3” intermediate pipe? Either size is going to be restricted from the 3" intermediate pipe so..
I’m leaning toward the 2-1/2” into the single 3” pipe to help with ground clearance.
whats your thoughts??
Old Oct 19, 2011 | 01:47 PM
777's Avatar
777
Unless you're making a lot of power..ie. 500+rwhp you won't notice much difference in a 2.5 and a 3" y-pipe.
Old Oct 19, 2011 | 04:26 PM
TImmy_Jones's Avatar
Dual 2.5" pipe supports around 500RWP...the real bottleneck is the 3" pipe.
This winter I am going to do a dual 2.5" into a 4" back setup.
Old Oct 19, 2011 | 05:13 PM
38DD2436's Avatar
A true 3" single exhaust will handle up to 400hp.
Old Oct 19, 2011 | 08:19 PM
99Bluz28's Avatar
Around 340hp would probably be more accurate.
Old Oct 20, 2011 | 07:42 AM
Steve Gunn's Avatar
Personally, I wouldn't reduce the pipe at all after the header flange. I'd rather scrape than compromise power or sound. If you're really worried about clearance, go with an oval pipe in the problem areas, then as big of an I pipe as you can to a cutout. If I could run 2-6" inch stacks with flappers out the roof of my car, I would.
Old Oct 21, 2011 | 10:38 PM
Blk98Vert's Avatar
Im with him. The only reason I would reduce the piping would be to run 2.5 inch TDs or if the headers had a 3.5 inch collector
